Arcan ®   26-Apr-2020 13:42
Furuno Doppler Speed Log DS-80_Operators Manual
Year: 2003
Language: russian / english
Author: Furuno
Genre: Technical book
Publisher: Furuno
Edition: M1
Pages count: 40
Description: The FURUNO DS-80 displays ship’s speed
relative to water, using the Doppler
principle; ship’s speed is measured by
detecting the Doppler shift frequency from
the signal returned from the watermass.
The output is interfaced with ARPA, AIS,
and other shipborne equipment in IEC
61162-1 format.
The main features of the DS-80 are
• Simple operation. In most cases all that
is required to display ship’s speed is to
turn on the equipment.
• Pair-beam system effectively reduces
error caused by pitching. The transducer
assembly symmetrically emits two sonic
beams, one fore and the other aft. By
averaging the Doppler shift in both
directions accurate speed data is
available under rough sea conditions.
• Speed and distance information on the
adjustable-contrast LCD display.
• Analog display, digital Indicator and
digital distance indicator display
optionally available.
• Conforms to the following standards: IMO
A.824(19), as amended by MSC.97(72),
IMO A.694(17), IEC 61023, IEC 60945
(3rd edition), IEC 61162-1 (2nd edition)
Furuno Doppler Speed Log DS-80_Installation Manual - Furuno [2019, PDF]
JRC Doppler Sonar Instruction Manual JLN-550 - JRC [2013, PDF]
JRC Doppler Log Instruction Manual JLN-205Mk2 - JRC [2013, PDF]
Furuno Operator’s manual Doppler Sonar Model DS-60 - Furuno [2010, PDF]
Furuno NAVTEX Receiver NX-700A/B Operators Manual - Furuno [2015, PDF]
Furuno Operator’s Manual Echo Sounder Model LS-4100, LS-6100 - FURUNO [2002, PDF]
JRC Echo Sounder Instruction Manual JFE-680 - JRC [2012, PDF]
JRC Echo Sounder Instruction Manual JFE-380 - JRC [2012, PDF]
Furuno Navigational Echo Sounder FE-700 - Furuno [2000, PDF]
Furuno Felcom 70 Inmarsat Fleet F77 Operators Manual - Furuno [2009, PDF]
The time now is: Today 05:27
